Just starting this pricing business my guestimate came in at £2040 and wokerd as follows
11 sockets and FCU 12 x £75 = £900
4 light feeds inc switches 4 x £75 = £300
24 down lights £240
CU change £600
Material Cost approx £500
5 days labour 1 man £200 p/day
total cost approx £1500 leaving £540 as a contingency
Thanks guys thats just sorted my pricing structure out ;)
I always chuck an extra day on top of what you think, that way if it all goes to plan you leave with a grin on your face, and if it doesn't at least you're not getting stung. I would be very surprised if you did all that lot with no hiccups, something's bound to waste a bit of your time. If he was sorting all the GU10 downlight holes though then that's a fair few hours saved trying to measure and miss joists right there. I just go by materials+10% +£300/ 10 hour day and always round the days up. Obviously then look at the end figure and adjust either way depending on what your gut instinct is on how much you thought the job would be worth and whether or not you want it of course!
I seriously need to sort prices out. At the moment I really am plucking them out of the air though near always far cheaper than the other quotes/
It always seem to be the testing that takes my time up. Have always wondered how some guys have it done in an hour with the paper done too
If you used 50w GU10 lamps totaling 600w most dimmers max between 250/400w you would need to split the loads up have you considered this? I remember trying to explain to a customer once why they couldn't have a dimmer after I 1st fixed the lighting typically changing their mind half way through the job, it was an awkward conversation now I wont have more than 6 spots on one switch plus if you split them up you more than likely don't need a dimmer :-)
The spots are across 3 seperate rooms, 1 going to be a home gym, the other a lounge and then a small dining area.
They requested dimmers but yes the load is going to be split
Good call, I hate dimmers, was doing a job last week and when I turned the power back on there was a soft start dimmer in the livingroom which made me say eh? a couple of times lol
