DaveyD
Hello
Can I please have your opinions on cheap clamp meters ie Philex 83007R or similar. What do you think is the most reliable under say £50 , or should I wait and save. Only padding about on domestic work.
Kindest Regards
David
No good for earth fault checking as it's not got a good (low) enough resolution, so unless you have some other devious use for it, save your money!
Sercal Electronics are quite good, I have bought things from them before :) They do PAT Labels n things...
Highly recommend this as I got one for out here as the majority of my work here is now on equipment that as high protective condutor current and it does everything I asked of it.
Even in a domestic situation it will help you check the protective conductor current, if you have a problem of a tripping RCD, and I got 3 of these for just over 60 pound each, so not too expensive.
