J
j_mccl
I have a customer who would like a central heating pump to be switched from a light switch in a bathroom the opposite side of the building, does anyone know of a wireless solution to this problem
The pump is to circulate the domestic hot water around the building on a ring main so that the cold water does not have to be drained out of the pipes before the hot water comes through, the bathroom is the opposite side of the house from the pump which is in the kitchen about 20 meters away the customer would like the pump to start as the light switch is turned on
Old Dog, has posted the perfect link but i gotta be honest, im not entirely sure you can do this, without major alterations to the plumbing.
It might be best to fit a whole house pump that would pump the hot water when its called for, although this wont get over the cold water run off issue.
I have seen some installs that have a bronze pump to do exactly what you require, but as i said, needs some plumbing work too.
Wide range of bronze secondary water pumps from Grundfos and wilo HIE plumbing Direct
I have seen this product while searching earlier, the only thing that concerned me is would this transmitter work if connected to the light switch as it will be live.
I am not carrying out the plumbing work i have just been asked to put in the spur for the pump and how it can be switched
ye jason i agree even with the pump coming on before the water depending how it is plumbed
you will allways get some cold water first even instsant water heater are not instant
if that makes sense
hi not sure on that model but most will swich more than one light so convert bathroom light
to wireless set at same frequency to switch pump
if that makes sense
I think bronze pumps are designed to run 24/7 and circulate the hot water round the system so that its instant rather than have the CW run off.
I have only seen one working and i have to say it was very good.
BUT, the plumbing system has to altered/designed to work like this.
Jolly expensive i would think.
I would prefer the pump to be left on 24/7 but the customer asked weather it could be switched as asked, the house is being plumbed new anyway as it is a barn conversion.
If the house is being newly plumbed then maybe have a chat with the plumber on site and see if he recommends another method.
Good luck.
