J
j_mccl
I have a customer who would like a central heating pump to be switched from a light switch in a bathroom the opposite side of the building, does anyone know of a wireless solution to this problem
ye jason i agree even with the pump coming on before the water depending how it is plumbedOld Dog, has posted the perfect link but i gotta be honest, im not entirely sure you can do this, without major alterations to the plumbing.
It might be best to fit a whole house pump that would pump the hot water when its called for, although this wont get over the cold water run off issue.
I have seen some installs that have a bronze pump to do exactly what you require, but as i said, needs some plumbing work too.
Wide range of bronze secondary water pumps from Grundfos and wilo HIE plumbing Direct
hi not sure on that model but most will swich more than one light so convert bathroom lightI have seen this product while searching earlier, the only thing that concerned me is would this transmitter work if connected to the light switch as it will be live.
you will allways get some cold water first even instsant water heater are not instant
if that makes sense
I would prefer the pump to be left on 24/7 but the customer asked weather it could be switched as asked, the house is being plumbed new anyway as it is a barn conversion.
