Discuss Borrowed neutral question. in the Australia area at ElectriciansForums.net
ban all sheds i dont think you can accuse people of doing a "bodge job" when what they are doing is well within the regs and is totally justified in the real world. I think everyone on this one is going to have to agree to disagree, job done, lets all have a big forum hug and wrap this one up because i'm getting bored of keep logging on and reading about borrowed neutrals when i should be watching eastenders. :banghead:
i knew there was somebody , somewhere that watched it, other than her indoors.
As said already said you explain to the customer that won't pay for the extra cabling, that both light circuits will now go off together (in the event of a fault on one) and you suggest they get some table/standard lights. I reckon if you take this argument to its logical conclusion every circuit should be on an rcbo. All the little 2 bed houses round my way only have one lighting circuit for up and down anyway lol.
I just read the thread from one end to the other ughhh :yawn:
There is the "reality gang" who do the best they can with what they have got and with no "trade muscle" like the gas boys can call on
Then there are the "angels of perfection",unfortunately they live on earth, with earthlings, and their earthly ways,
Angelic attitudes, unfortunately, doesn't put bread on the table :waving:
Hey pushrod...make sure you tell them they can't have an RCD or RCBO fitted, also no new downlighters in the bathroom etc....unless of course they happy to have all the 1st floor lights rewired !!!
I am really suprised by some of the threads I've read, and I dont see why a borrowed neutral from 2 lighting circuit should be a big issue. As someone said, why should you ripped the property apart for one friggin neutral. Remember this is a fuse board change, as long as the load is corrected, a warning notice and its recorded, also, yes it can be a danger if this hasn't been adhered to. If borrowing a neutral from the socket for a light then I would have said its a NO NO.
Note: if you decide to run a neutral, never run one on its own, if I'm right as someone suggested.
521.5.2 (p97)
FERROMAGNETIC ENCLOSURES: ELECTROMAGNETIC EFFECTS
The conductors of an AC circuit installed in a ferromagnetic enclosure shall be so arranged so that all line conductors and the neutral conductor, if any, and the appropriate protective conductor are contained in the same enclosure........
First amendment my back side. they should have looked well ahead before they leap. why is it so soon very 10- 13yrs when the regs are updated. I think we definetly all know the answer.
New posts
Reply to Borrowed neutral question. in the Australia area at ElectriciansForums.net
I have a client with what appears to be an intermitent fault on the lighting, but trips the power. The installation has a 16th edition board with...
During some testing I found a N-E IR fault on the kitchen lights of 0.1Mohms. I also found a N-E IR fault on the ring sockets, again 0.1Mohms...
8K
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi, I have just replaced an old rewireable fuseboard with a 10way consumer unit with rcbo's fitted. The issue i have is that when i connect one of...
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
