D Skelton
Mentor
How do you guys do it? Referring to the two pictres below, what are the pro's and cons to the two different methods? I'm trying to settle a minor dispute with a friend :)
both ways are acceptable, i use the left one if only to do away with 1 choc connector. BTW, where the hell did you get the software to do such diagrams. i've been looking everywhere.
Less connectors, I guess.
Personally I dont use any, strip the sheath back, cut strappers leaving the brown continuous.
DIYnot.com Tel
Funny i'm the opposite Tel I prefer the choc block as I'm just a lazy so and so and terminating 2 cables into a faceplate terminal is not my idea of fun
Well DS take no notice as it seems we are the only 2 so far that do it the right way, the others would rather stuff 2 cables into a small termination of a switch plate and leave the chance of having a poor termination that could be a point of an heat spot that could lead to a breakdown or in the worse case heat damage and fire .............:shades_smile:
That was my exact argument too :) at least with one termination in each you can bend the cable end providing a nice tight termination but with two cables, terminated into one termination, you can't do the same for both.
Edit: Just realised what a mouthful that sentence is haha. termination termination termination
but with 2 ends in the switch terminal, there's less chance of a single end missing the screw and falling out. all depends as well on the size of the hole.
:6:
Malc/Skel
you two must really struggle when doing a two way using a three core and earth. Getting the strappers, s/w, s/f in those pesky terminals. Or is done using connector and taking the s/w to other com term?
:6:
And when putting a single cable in a hole we double the end over, effectively making it two cables to fill the hole. So is there a problem in getting two cables in a hole?.............ER no.
What on earth are they on about Tel'?
I would have made that point too, although I would have been a bit less patronising in the way I made it :)
Malc/Skel
I'm not quite sure I understand your question. Am I being dumb?
Okay,
How do you do a two way circuit?
Patronising? Me? just av'in a laff.
