at least with one termination in each you can bend the cable end providing a nice tight termination but with two cables, terminated into one termination, you can't do the same for both.but with 2 ends in the switch terminal, there's less chance of a single end missing the screw and falling out. all depends as well on the size of the hole.
:6:
And when putting a single cable in a hole we double the end over, effectively making it two cables to fill the hole. So is there a problem in getting two cables in a hole?.............ER no.
Malc/Skel
you two must really struggle when doing a two way using a three core and earth. Getting the strappers, s/w, s/f in those pesky terminals. Or is done using connector and taking the s/w to other com term?
