fair comments but how do you think the cables get to a socket when you do have access from under the floor? behind the skirting or by magic? it would only be a fire hazard if you screwed the face to the skirting without a b/box! correct me if im wrong but would behind the skirting still be a prescribed zone? and even so with it being buried less than 50mm from the surface it would also need rcd protection so if sum 1 is stupid enuff to put a nail or screw thru a skirting board without checking whats behind thats their problem i have done my job and in line with the big red book :)
Hi
lets clear this up behind a skirting board has never been a cable zone nor will it ever be. Some scary posts, I here a lot of this its on a RCD so don't worry, RCD are additional protection not a back up if it goes wrong.
regards
RapidRich
How far does the socket have to be from the other socket already in the room?
Regs state that you can chase a wall horizontally up to a 6th of the thickness of the wall. I know it's not ideal but it is another option.
Regards
Mark
Kung
Just had a look at the D-trunking, and it looks pretty good mate. Much easier than chasing!!
Mark
