Discuss spare socket in the Australia area at ElectriciansForums.net
And no you should NOT run any cables behind skirting board.
Your only other option is to use some mini trunking run around the top of the skirting from an existing socket with a 13A plug top and some 1.5mm 3 core flex to a twin socket, surface mounted.
Not ideal or the most attractive but if budget and access is an issue.
fair comments but how do you think the cables get to a socket when you do have access from under the floor? behind the skirting or by magic? it would only be a fire hazard if you screwed the face to the skirting without a b/box! correct me if im wrong but would behind the skirting still be a prescribed zone? and even so with it being buried less than 50mm from the surface it would also need rcd protection so if sum 1 is stupid enuff to put a nail or screw thru a skirting board without checking whats behind thats their problem i have done my job and in line with the big red book :)
Did you read the entire post?
We are saying that cables should not be run along behind the skirting board, not coming up from under the floor and going behind the skirting.
yeh i did but i had just got in, i admit its not my 1st choice for cable routing and infacts its something 1 of my old bosses used to do if i did it half the plaster would probably come with it but if its on an rcd and you cant see another way i dont see the problem
Hi
lets clear this up behind a skirting board has never been a cable zone nor will it ever be. Some scary posts, I here a lot of this its on a RCD so don't worry, RCD are additional protection not a back up if it goes wrong.
regards
RapidRich
How far does the socket have to be from the other socket already in the room?
Regs state that you can chase a wall horizontally up to a 6th of the thickness of the wall. I know it's not ideal but it is another option.
Regards
Mark
Reply to spare socket in the Australia area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
