Either a single to three phase inverter or a three phase generator would be the options. Might get a bit expensive for a big load, what's the rating for the two machines?
Thanks chaps..... not sure on ratings just yet, off to look at job on Saturday. Think inverter may sounds like the best solution. Just wanted a bit of info before hand so I don't look like a right plank.
What about calculating my loadings, say if the motor was rated at 3kW three phase, what single phase supply would I need to run the inverter ? Sorry if this sounds a bit basic and I'm sure there is a simple answer but I've never used an inverter before.
If they are dual voltage motors, IE 230V delta, 400V star the inverter is a good option. 230V 3ph you can get away with a single stage inverter, 400V you need a two stage, which is more expensive. You need to do some research.
