E
Engineer54
A loft conversion will significantly increase the value of his house. A rewire will not.
The number of rooms in the loft conversion is irrelevent, there are 4 circuits the load is big, and a new C/U will have to be installed somewhere anyway. The guy clearly stated he wants to save money, and this would ultimatly be the cheaper solution.
lol!!
But it WILL save him having to reduce the price of his property when he sells it, to cover the cost of rewiring the place won't it??
So what are you saying, every time you add a small extension or whatever, best to bung in a CU to cover it, cause the guy won't invest in updating his main CU or in rewiring it!!! So over a period of time you could end up with 3 or 4 CU's in a standard 3 bedroom house This is getting sillier by the minute!! lol!! You START with the basics, you don't do the basics after major re-fits.... And starting with a CU change or if required a full rewire is, or should be considered a Basic Requirement!! More importantly, It also gives his family a safer environment to live in!!
