Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
Somebody mentioned these to me the other day. Silverline do one for £30 (plus arbour) with 5 plugs. Anybody use one and what are the advantages and disadvantages please?
I used mine again yesterday. clean cut nice bit of kit the discs are a tenner for 5 from the tool station. advantages cheap enough. disadvantages they burn your fingers if you stupid enough to touch them when they are still hot
They are really useful on sheet flooring where you don't need significant access under a floor. The defo have their place in the armoury of tools which can help a job go more smoothly!
Been using the routabout for about 20+ years, it needs a reasonably powerful router or the router will stall if there are any hard spots in the floor board or you try to cut to much in one go. I would recommend using the half inch cutter as the quarter inch cutter tends to flex a bit and can snap if your not careful
Had customers in the past ask me to cut access holes with it so they could use the access hole as an underfloor safe to store valuables out of the away
I find using a combination of the routabout and the Armeg / Silverline board cutter and plugs works well for running cables underfloors and through joists
Just trying to find a uk supplier of these www.flexidrills.com/pages/dura-drill.html
but may end up importing some if I can work out the import duty and costs.
I have an old one that is 6 foot long it's great for stud walls and also drilling joists between access holes but it's getting a bit worn out. Had some of the others in the range for drilling behind coving and other awkward things but these were loaned out and never seen again
I think the 6' long ones are called installer bits. I was given one about 20 years ago by an American customer. Very useful but got over abused as I used to use it like a flexible shaft drill!
