L
leekemp85
I have been asked to change a mains board in a small office as there are no spare way.(the building was tested a few weeks ago and I have been asked to do the work that failed.)
Am a qualified electrician registered as a sole trader but not yet in the part p scheme am I legally aloud to do this.
And if changing an mains board will everything need to be on rcbos or just the new circuits the other electrician put a code 2 that circuits were not on rcd (I thought this would be a code 4 as you can change every circuit to rcd just because of new regs)
many thanks
many thanks
should you undertake sub-standard work.
