Re: PV Panel War: Sanyo v. Hengji. The ultimate side-by-side long-term, real-world t
Awesome experiment, very well done. Great for mere mortals such as myself!
Irrespective of second order effects, I feel that the OP should be applauded for running the test. As has been stated many times on every PV forum, data is only useful under real world conditions and under the same conditions. Placing arrays as you have is about as good as you can sensibly get. I see no issue with shading. Most of us have some. It will be interesting to see how the two panel types behave given the fact that their diode arrangements and bypass zones are totally different. I would like to see some form of dappled shading retained across the whole array as this is far more real world.
Indeed, I agree as in the olden days we had ppl like "WHICH" who use to do tests/comparisons of such nature..........
At face value, this appears to be a good experiment. If it was meant to be 100% scientific then it would be taking place in a lab! This is being done in the real world, in real life conditions so would be keen to see the results.
Part of the reason I have replied to this thread is so I can stay up to date with it but having tracked down the co-ordinates to somewhere around Tibenham, I am only about 6 miles away so the data would be very interesting from a local, personal point of view.
I am currently monitoring 2 systems: Suntech v Sanyo Hits
Suntech monocrystaline panels are outperforming Sanyo Hits in low light conditions by 10-15%, but underperfoming significantly in bright conditions (40%).
After a "Burn in Period" The Suntech 250W are now performing better in low light conditions and very close to the efficiency of the Sanyo HITS in bright light conditions.
Moral of this story? Sanyo HITS are far more expensive, but dont outperform as much as they need to, to justify their economic outlay.
The Sanyo Hit panels are currently outperforming the monocrystalline Suntechs by 4-5%. They cost a 40-55% premium.
To be totally honest, I am a fan of Suntech panels but this just isn't good science. The Suntech panels are fitted at a better pitch (30 degrees) than the Sanyo system (45 degrees) and we know very little else about the systems.
The data suggests that both systems are south facing and unshaded - now we all know that if they are going by SAP calculations then zero shading doesn't exactly mean just that. We don't know how the inverters are mounted, how far the cable run is or pretty much anything else about it.
Thor v Uxello Solar:
Ask questions and enter the debate....
Help me explain why the latest Suntech monocrystallines should be performing so well relative to Sanyo 250 HITS on 2 similar systems 10km apart.
The Suntech solar array with transformerless inverter was earthed on the 28th March 2012.
Since that date the 2 systems relative performance has narrowed.
Great experiment would love to hear how its all going over the course of the year(s) to come.
Sent from my iPhone using Tapatalk
How can you be sure that they are in equal conditions?
The only way equal conditions can be found is by installing side by side.
Do you know a millionaire locally that will fund such an experiment?
I'd be happy to see the results.
I know what we'd find, that the Sanyo 250 HIT's generate marginally more than the
latest Suntech's. The Suntech STP250S - 20/Wd monocrystaline panels have a
module efficiency of 15.2% versus 18% on the Sanyo HIT-H250-E1.
The Sanyo HIT 240's are 19% and the latest Sunpowers at approximately 20-21%.
All are very much more expensive.
Economically they wouldn't be worth investing in over 25 years, unless maximising
solar power generation for a fixed size of roof, where panel size affected the amount
of panels that could be installed in a limited space.
Anyone with a commercial interest in installing Sanyo Hits would be likely to
challenge these results, as they have economic interests to protect.
Unfortunately I dont.
I care to find the best quality panel, outputting the most energy over 25 years, In
typical conditions that prevail in North West England.
If I lived in Greece with greater average sunshine another panel may be my panel of choice.
Some PV panels perform better in low light than others etc.
Some perform better in high light conditions and greater temperatures etc.
Choosing the right solar panel for your environment, depends on where you live, the
typical weather conditions that surround you, your size of roof and a few additional
factors, IMHO.
As would I.
All I am saying is that to compare these two systems is not very good science, particularly when you understand just how much impact orientation, pitch and shading can have on a system.
To take these two systems and then to go and make a conclusion based on the results is not going to very accurate.
Unless you have tried to do your homework and understand the impact of such factors....
The difference in roof declination of 30 Degrees compared with 45 degrees amounts to a potential difference of 4% in system output of comparable systems, if the roofs are within +/- 10 Degrees of Due South.
If the roofs are orientated within + or - 40 Degrees of Due South, the difference in system output can be as much as 7-8%.
I know these 2 solar systems have comparable shading, that they are located close to one another at similar altitudes / orientations and that they have similar weather. The roofs have a different inclination, which affects output between the two systems by 4%.
I have tried to compare the outputs of 2 comparable systems scientifically, but others may agree to differ.
I have found the latest Suntech STP250S - 20/Wd to compare favourably to the
Sanyo's 250 HIT's. I am seeing a 4-5 % difference in generation between the 2 in current climatic conditions in March 2012 in North West England.
If the Sanyo Hits lost 4-8% maximum generation output based on roof declination / orientation in a worse case scenario, how much more energy are they likely to generate than the Suntech STP250S - 20/Wd solar panels for a 40-50% cost premium? 8-13%?
I know these 2 solar systems have comparable shading, that they are located closed to one another at similar altitudes / orientations and that they have similar weather.
I'm not trying to be difficult, I'm just trying to make sure that the analysis is accurate.
Have you seen the sites and compared them both or are you just going off the PVOutput details?
To compare these two systems is not very good science, particularly when you understand just how much impact orientation, pitch and shading can have on a system.
If there is no shading and we know the relative pitch is 30 Degrees versus 45 Degrees and the orientation of both houses is within 10 degrees of due south, both houses use similar inverters on comparable sized systems, we know the panels on both roofs, the houses are within 10km of one another, the panels are both orientated landscape on the roofs, please explain why such a real time experiment cant glean us any useful information?
It seems to me that in this world there are too many people, protecting their interests or failing to employ common sense.
It is clear that Sanyo HITs are excellent solar panels, but they are far too over priced for what they are and many competitively priced solar panels exist to replace them with.
To say this publically comparing "apples and pears" presenting real time analysis of 2 similar systems in the real world, threatens people with a vested interest in stocking and installing them.
It is not difficult to see the relative performances of Sanyo v Suntech solar pv panels, but until they are put side by side, all and sundry will argue about one panel versus another until definitive proof exists one way or another.
IMHO Sanyo's HIT panel systems are 20-30% more expensive to buy and generate 5-12% more KWh than comparable Suntech PV systems, in comparable locations, with similar roof inclinations and climate.
well if it's 4-5% improvement, then this is in line with what we've been estimating for our performance estimates.
The cost premiums you give though are pretty misleading, as these purely compare the panel prices, rather than the whole installed system prices. The difference in the system prices is around 20-30%.
The major benefit of installing Sanyo systems though comes on roofs with limited roof space where the Sanyo systems can usually fit between 20-30% more actual generation capacity in the same roof area. At this point, this plus the 5% improvement in performance starts to make the payback times / ROI for a 4kW Sanyo vs eg a 3.3kW mono system be relatively equivalent.
Before the big price cuts recently the Sanyo systems actually came out better in those calculations than the cheaper systems most of the time. The situation now is a little different as the standard PV prices have dropped so much, but it's still worthwhile enough for more than half of our installs last month to have been Sanyos when we quote and give performance estimates for both options. Not sure what it will be like at 21p with no potential for 43.3p FIT mind, time will tell, but my feeling is that the Sanyos will still be popular.
If there is no shading and we know the relative pitch is 30 Degrees versus 45 Degrees and the orientation of both houses is within 10 degrees of due south.
How do you know there is no shading? I know it seems like a strange question but I visit plenty of sites where an installer and the customer has declared that there is no shading. They have also measured the orientation of the roofs poorly. I have seen plenty of SE or SW facing roofs with chimneys and neighbour's roofs shading parts of the array where other companies have run SAP figures as south facing/unshaded.
I'm not saying it is not useful. I am saying that it is providing information. It is how you interpret this information that is important. To look at two different arrays on a website and draw conclusions on that is just bad science - there are too many factors that you cannot know.
You seem to be implying that I stock Sanyo panels and that I'm therefore trying to give them a public 'boost'. You are incorrect. Indeed, if you do a search, you will often read comments from myself praising Suntech panels as a better value for money option than Sanyo.
I know its only nearly 3 months from fitting but do we have any conclusions/updates yet?
These experiments, although possibly flawed (though I would say in relatively fixed manner which could be eliminated to a reasonable extent), are better than anything else we have to go on. When installing my system I found most installers didn't understand the basics of the Physics, so had no way to explain why things like shading matter (I have a wife with a Ph.D. in semiconductor Physics so have an insider :-) ), so any real world comparisons, no matter whether they're 100% comparable is going to be useful. And thanks for doing these.
My system is Sanyo based, not for any other reason than I wanted to get the most out, didn't care so much about the cost, and at the time the difference in price wasn't 40-50%. Now it's been installed for 6 months, I've noticed several interesting facts, I have shading issues on some of the install, and used micro-inverters to ensure the system wasn't as badly impacted. I also need the highest output for the size of panel, since if larger panels were used more of any panel and possibly more panels would have been affected by the shading, if I could get the same number on the roof.
1) No panel produces the same output, even where I have panels in a rectangle in full sunlight, each will disagree with the neighbour above, below or sideways by as much as 10% and almost always there's a variance of 2% between neighbours. So any test with a large array next to another large array is never going to be perfect, but better than nothing.
2) The angle of the panels affects the output more when the sun if full on, I've got 2 pairs of 4 panels facing the same direction at the same height but slightly different angles, at this time of year I get between 1 and 5% difference in output between them, peaking around lunchtime and early morning/late evening there's no difference, however, over the year, I expect the benefit to switch between the two as the sun gets higher still.
3) Temperature is a huge factor, when it's chilly and full sun, my panels exceed spec. by around 11%, now the sunshine has arrived nowhere near this level (although it's potentially more hazy with the overall increase in air temperature). Also, they still generate with snow - though not huge amounts of electricity, unlike my thermal panels which ran continuously during a sunny winters day, covered with around 10cm of snow.
4) My chimney stack that put 90% of installers off, because it couldn't be done, rather than can we minimise the impact, at this time of year, is only shading one panel to any level, the shadow itself has shortened significantly to the point it only glances 2 panels and shades a 3rd. But of course at this time of year I'm doing 85% of the annual generation, so the actual impact is less significant than anyone predicted (yesterday I generated the same in one day as the whole of December). I've never once seen an installer consider anything beyond the that tree or chimney shades the panel, don't install. My neighbours were told by an installer that we were stupid as they wouldn't work, whilst I'm watching the shaded 5 panels generate nearly 1kWh at 10am, and a lot more at lunchtime.
mike
Very similar for me .... Sanyo and Enecsys with some shading (but less of an issue with higher sun). We're down to about 80% efficiency with the hot weather. A few days ago we were touching 100 and even occasionally beyond.
Today has been the first day ever where we experienced a near perfect bell curve. Up until then the chimney had caused some shading. It still does but only after 5pm.
Even so, best performance ever in the past couple of days. It's never going to be as good as a gentle inclined roof with no shade but it looks a whole lot better than it did a few days ago.
1 month ago I peaked at 264W from a single 240W panel, and my best ever day under cool conditions, 15th April, we peaked at 262/263W across 9 panels and the remainder showing 255W or more, with the exception of my panel that can't communicate until evening.
One thing I have noticed, even with shading, for the first 6 months, which is roughly the a mirror of what you'd expect for the second 6 months, both my main panels with shading issues, have still managed more than 60% of the total managed by the panels with no shading whatsoever.
This is interesting because there was the choice to drop those panels from the system altogether saving something like £1000, but in reality only 40% of that number because we're not gaining the electricity either, so on balance I've lost £400 of that figure, all of the other costs would have remained static, but both of these panels is currently on target to achieve £50 per year or more, meaning that they pay for themselves in around 8 years, which is actually around the predicted pay back of the whole system.
The conclusion I can come to is that it's worth fitting panels in shaded positions providing
1) By not fitting them you don't save more than the cost of the panel/micro-inverter.
2) The shading should not cause more than 50% of the day to be lost. In reality only in the summer does this matter, it can be in full shade for november, december and january and it won't have much impact.
3) If you use a sting inverter, you have to be sure you don't compromise the whole string when a shaded panel is in the string.
Point 3 is interesting because the unwritten rule from the installers perspective seems to be one panel out, all out, unless the string is large enough to cope - in my case it wouldn't be. Depending on whether this rule is true or not, and I don't have any evidence either way, except to know, a panel with only a small amount of shade (maybe 10-20%) fails to operate. But if this is the case it proves the sense in fitting micro-inverters over standard string inverters in many cases where shade is unavoidable.
mike
fwiw, we produce full 3d models of every building we install on and can estimate the shading impact very precisely on average for each hour of daylight for each month of the year, and use this to design the system to absolutely minimise the shading impact.
We actually don't use micro inveters though, as we've never found a situation where the figures stacked up to mean that their benefits outweighed the reduced efficiency of the micro inverters vs an SMA 4000TL, which with Optitrac global peak enabled will already greatly reduce any shading impact on a properly designed system to get the best out of the panels in built bypass diodes to bypass any shaded strings of cells.
Took us a fair amount of time, effort and scratching of heads to get to that point though.
I went through 18 installers, and not one, even the one we went through had any kind of 3D modelling.
On the efficiency situation, I'm not sure I'd agree, from my personal situation, you'd never be able to achieve a string big enough for an SMA inverter to work efficiently with one or more panels shaded, which would mean for the period the shaded panels are doing nothing, an SMA inverter would do nothing.
My main concern with the efficiency figure is the fact that everyone seems to assume all panels side by side produce the same output all the time, but when you have the ability to view each panel as you do with a microinverter, you get to see quite a variation, even simple things like vapour trails from aircraft can affect the output of a single panel - due to the fact I've got panels with a spread of 14m you can see the output change as the clouds move across the sky.
Unless SMA have managed to break the laws of physics there is no way they can optimise the power across a string so that the power output is the sum of the total, only the most efficient for the system as a whole.
In my case the difference between the side by side panels is larger than efficiency difference between the best SMA inverter and the Enecsys micro-inverter, but I only have 3 pairs of panels where they can be said to have absolutely identical sun.
This is what makes this kind of experiment very interesting, I'd like to see the same experiment, but looking at microinverters against string inverters, we all have our own beliefs, but no one seems to have the hard facts. My best guess is that in reality there's little difference between the two, so cost is the only factor, but in my case it actually wouldn't be possible to get a string large enough so it's not a choice.
Perhaps the most interesting fact is that I've got some friends, their roof isn't shaded, and points in the same direction as most of my panels, I do have a set of 4 pointing slightly more southerly, both ours and their systems are within 1% of the same output, and both have identical numbers of identical panels.
I should also point out, the installer I went for, was the only one to consider installing a very esoteric system rather than a slap it up as fast as I can to maximise my profits which pretty much the rest seemed to want to do. I think the avoidance of micro-inverters is in a large part simply because it costs the installer more to install.
mike
no laws of physics being broken, they've just used a function that sweeps the VI power curve from top to bottom every few minutes to find the actual peak point instead of getting stuck on a false peak and riding that all the way down to nothing.
Basically what they're doing is making it so that the bypass diodes in the panels are used properly, particularly in situations where the shading rapidly impacts on several strings of cells at once, which often takes the new peak voltage outside of the range of the sweep of the standard MPPT tracking.
If the bypass diodes are enabled to function properly, then it allows the unshaded portions of each panel to output at their optimum point instead of being dragged down by the shaded parts of the system.
I'm not sure if I'm explaining this right, it's a bit late, but the bottom line is that it's surprisingly effective. Obviously you can only install on maximum 2 roof faces, and need a minimum of 4-5 high voltage panels per string, but frankly I detest the look of systems with panels dotted around all over the place, and am of the opinion that such systems will actually cost the customer money in the reduction to the houses value from the poor aesthetics, so for me it's not really an issue.
There is potentially an arguement for microinverters with sanyo panels as the sanyo panels have a +10% tolerance on them, and strings will always operate at the output of the lowest rated panel in the string, so if the variability really is this great from panel to panel, it could potentially have a greater impact than the +2-3% efficiency of the 4000TL vs enercsys. I'm dubious about this, but would be interested in some real world comparative data from panels on exactly the same slope, orientation etc if you had such data.
mike
I don't know about anyone else, but if it costs us more to install, then the whole system would also cost the customer more, which is another factor. I don't know the exact figures, but if it were an extra £500 for enercsys, then it'd need to provide 5% benefit vs a string inverter just to cover that extra upfront cost.
tbh, I don't think there's much in it either way providing the system is modelled fully in advance and designed carefully to mitigate the shading impact.
I find this whole thing very interesting, my wife who has a degree in Physics and a PhD in electrical engineering, specialising in semiconductors explained it to me, how the MPPT could never achieve as much as treating each panel at an individual level, basically the sum of the parts will always be greater than the sum of the total because each panel is optimised or the whole system is optimised, but whether this was significant or not, who knows, what is very significant is the Physics involved in the conversion of photons to electrical energy, and this is where clouds can have a big impact as the shadow moves across the panels, but again, it's not measurable in any meaningful way.
Personally detesting the look in my opinion is only excusing a lack of willingness to consider the options, in my case, 9 panels are hidden from the front, and 8 of these sit on top of flat roofs that don't have any aesthetics to lose :-). But if aesthetics are important, surely the only option is solar tiles, which incidentally I did get a quote for, but it put the install, off the scale, for price.
I'd love to give meaningful figures but I've yet to find a way to record the Enecsys figures beyond the totals they show, for day, week, month etc. and this is looking at the data with sufficient detail. I have collected the odd snapshot throughout a single day to see what happens, but you'd really need to capture every reading for every panel throughout the day, to analyse it in any meaningful way. If a shadow from a cloud moves across the panel at the same speed, the effect on a micro-inverter system is for both panels to record the same total, if using a string, the effect is to lower the overall output for the duration of the shadow on either panel. But if you looked at the instantaneous readings, you'd see one panel was generating maybe 10 or 15W less for the duration of the cloud.
My best figures I can come up with, for 2 of the pairs that are in consistent conditions, and they're flawed for the reasons above:
Pair 1: Today: Same reading Week: Same reading Month: 18.37 vs 18.45 Year: 64.84 vs 65.17
Pair 2: Today: Same reading Week: 2.49 vs 2.48 Month: 19.14 vs 19.07 Year: 67.92 vs 69.88
Pair 2 is interesting as the panel that's achieving the most has swapped over.
Another interesting factor is temperature, and I suspect worrying about clouds and positioning is probably largely irrelevant compared to temperature, we know how much heat can affect the generation efficiency, so the middle panels in any array, could potentially be under-performing the outside panels due to heat build up. Now we're in the summer I'm seeing my flat roof mounted panels exceed the generation of the roof mounted panels by a much larger margin than any of the efficiency differences, which is probably mostly to do with heat. My roof mounted panels were always the best during the winter by 10-15% and this situation has reversed by roughly the same amount.
There are so many factors that could affect solar generation, I found it quite dismaying that micro-inverters were rejected out of hand by so many installers. I think the reality is as you say, the cost is more significant than any benefits, unless the system cannot function without.
I suspect my install is one of the most esoteric out there (and my reasons for maximising generation at whatever cost), and it would not be possible to design out any of the shading issues, simply because orientation of panels is largely fixed due to various factors. I would have loved a 3D model, but given the cost is nearly half that of fitting an extra panel, you'd wonder whether the suck it an see approach is just as valid as sitting there and trying to do the maths.
mike
With my system the Sanyo panels were chosen mainly on grounds of yield per square metre. We could fit 3.5kwp on the roof without it looking like a chess board. I wanted something that would be, at worst, neutral upon the look of the house from the road. My feeling is that this is one of the few installs that actually enhances the look of the house as it gives it a slightly more modern feel.
The problem with going for something that looked reasonable was the fact that we have a large chimney on the front of the house and a chimney and aerial from next doors house causing difficulty first thing in the morning. Most installers just wanted to slap up panels in the middle of the house avoiding the shading from the chimneys. Our chosen installer suggested Enecsys and with a high up mount. Much more expensive but not outrageously so and virtually cash neutral when you factor in the twenty year warranty on the inverters and the fact that, at that time at least, a string would need replacing at some point.
His thought was that Enecsys would pull as much power out of the system as feasibly possible while string inverters would suffer to some degree. I'd read about clouds and I can see the effect of them, albeit delayed, on the monitor. I can also see the effect of the chimneys and aerials.
I will never know how much inefficiency exists within the micro inverter. All I have are the specs. Over 1.2M watt of production the Enecsys monitor is reading about 2.7% higher than the PV meter. meaningless I know, but it does give us an idea of the accuracy of the monitor.
One place where micro inversion does fall down with the Sanyo panels is bypass diodes. The HIT250's have a pretty high open circuit voltage and this necessitates the use of the higher tracking range Enecesys units. These also have a higher minimum tracking voltage for the MPPT and this means that the moment a panel reaches about 50% hard shade the inverter will shut down. We're this on a string the inverter would most likely keep the panel producing. This has proven to be something of an issue with our chimneys.
I've always taken the long view with PV. For me, it isn't about how quickly can I get my money back. I'm more interested in maximising my income each year. IT amounts to a similar thing but it isn't quite the same. Achievements so far show that the best performing panel (since November) has yielded 90kwh. Interestingly it is right in the middle of the array. The worst performing panel has managed 71.5kwh. This one is right behind the chimney. Now, I could have left a gap behind the chimney but the evidence shows that even the shaded panels will pay for themselves albeit over a 25% extended period or so. Now, given that the shading is far less at this time of year (nothing before 5.30pm) yet the sun is stronger, I suspect that the differential between the best and worst performing panels will reduce. I also suspect that the system losses of 2.7% will come down as the quiescent drain of power to run the inverters becomes less significant as solar yield increases.
If my system had been very low shade I am sure I would have taken a string based approach. As to if the micro inverter route was the best one... Who knows. provided I get close to or exceed my installers estimate (which offered a significant uplift over PVGIS) I cannot complain. It will take several years to compile enough data to be statistically meaningful... Certainly the data so far is not enough.
The upfront cost of Encesys is higher. That is a big turn off for both installers and customers. The fact that there is more hardware per panel install and the fact that even with a 20 year warranty somebody may have to come back several times and possibly install ladders or scaffolding is a turn off for installers. Some installers have a fear of something new. Some installers have a tainted vision given the poor reliability when Enecsys changed manufacturers. I can't blame installers for not advocating micro inversion. I cannot blame customers for reluctance to pay more up front.
Time will tell with micro inversion. I'm playing the long game and as long as my metrics are met, I'm reasonably happy.
As would I.
Gentlemen, I'm confused.
I'm the OP who, whilst not a 'millionaire' :) is running a side-by side experiment between Chinese and Japanese panels at my own expense (see early posts).
Please don’t derail this thread with details of other comparisons, where the systems are not actually ON THE SAME ROOF! It will confuse later browsers (including me).
Hi Gary
Thanks for your continued interest. The data so far are most interesting. And surprising. There is a temperature factor at work, but it’s relatively minor. I’m not going to say anything more until I have enough data which encompasses seasonal variations.
I also don’t yet have any up-loadable information, since we’ve been stuck on the supposedly simple matter of getting a legacy RS232/485 serial port working on a Win 7 machine. All the data remains locked inside the inverters for now.
Cheers, Mark.
… I have a wife with a Ph.D. in semiconductor Physics so have an insider :-)
Ha Ha! I live with a tame programmer/mathematician so clearly we share an interest not only in elec-trickery, by also in intelligent women :)
Cash and dash, we are all intrigued as to how they are performing, to be a fair test you want to run it for a year of that we appreciate, but could you give us any idea as to how they are against each other, just roughly would be great.
Many Thanks.
Been really picky, the only error I believe you have made is that you have installed the panels in specific groups at different parts of the roof, which could depending on environmental circumstances could cause some rogue results possibly. I think the better way for panel layout especially seeing its a comparison experiment, would of been 2 rows - 1 row of each make across the roof, one make above the other and/or crossed over 8 panels reversing make on top for make on bottom.... or if wiring would allow - mixup in an orderly fashion - a Sanyo panel then a Hengjji panel and so forth....
However apart from that I'm really looking forward to your findings - good work !
With all the focus on maximising putput, one of the biggest areas people would benefit from is maximising usage, as mick says:
I do hope mike, you've got a coolpower emma attached to that ...
Back to the OP's reasons for this, a real worl comparison over a year would be excelelnt - any chance of posting the data / hooking the inverters up to pvoutput.org?
Been really picky, the only error I believe you have made is that you have installed the panels in specific groups at different parts of the roof ...
That's not picky at all, it's an obvious point, and I agree absolutely.
I didn’t do it for historic reasons: I’d already fitted all the rail and 4kW of Chinese panels before the idea of doing a comparative test crossed my mind. It was reading all the arguments on this forum about ‘which panel is best’ that gave me the idea.
I immediately sold 4kW of panels on EBay and ordered replacement Sanyos. Time was very tight since I was aiming for the 3 March deadline.
Plus the work involved chipping ice off a slippery metallic roof to get the panels on. Handling metallic objects at -5C is rarely fun, so the idea of taking off what we’d finished already did not appeal. I also didn’t have enough PV cable immediately to hand to do a checkerboard array.
Now it’s sunny, I’ve toyed with the idea of changing it around, but I doubt I’ll actually do it, there just so much else happening at the moment (any volunteers? :)). At least they are side-by-side on the same roof, and I don’t think even that has been done before.
Due to the great disparity in price between the two systems, I am looking for a major difference in performance, way beyond any ‘Ah but that end is more shaded at 07.00’ type argument. Even allowing for the possibility of differing average illumination levels at each end of the roof, with a 50:50 chance of it disadvantaging the Sanyos, I would still expect them to provide statistically significant greater generation.
Many Thanks.
Apologies for the suspense :)
But I'd better be careful: there may be liabilities attached to the results - they may well show that one type of panel has been mis-marketed, leading to all kinds of legal claims from previous buyers. The UK's Sale of Goods Act is pretty clear about manufacturers' claims. So before I release the data, and take full responsibility for it, I need to make sure that what I have is both irrefutable, and statistically significant. It might be big news. Or it might not. Kindly stay tuned :)
the last couple of days should have given a good indication of whether the sanyos are likely to start significantly outperforming the others through the summer.
FWIW I wouldn't have expected much different up to this point in the year, but most of the generation will be May-September, so it's the advantage at this time of year that really pays dividends.
I've probably said this already, but we work on around a 5% improvement with the sanyo panels in our estimates. I'm hoping this is about right, but wouldn't expect it to be much higher than this - probably slightly lower if panel voltages were the same (slight improvements in inverter efficiency usually from the slightly higher panel voltages).
I think you will be OK on that one because all panels are tested under stc, so that one can compare a panels performance to another tested in the same conditions, but what you are testing is real performance, in real conditions.
This test could possibly show opposite results if it were say in California.
But thanks from all of us (well most).
Can we have somekind of interim results please.......................
If The HJ Solar panels perform well in low light conditions versus the Sanyo HITS (like the Suntech's do) it will be no surprise to me if the HJ Solars outperform the Sanyo HITS through this period of unsettled, cloudy, wet weather.
Well if somekind of conclusion based on 5mths of results is still NOT forthcoming, its time to give up..... unless there's other purpose to the thread ?
It needs at least several seasons to compare properly. If I publish results now there will follow a tedious barrage of 'aah buts' and 'what ifs' which I wish to avoid. The performance of different manufacturers' panels varies under differing meterological conditions, day lengths, and temperatures.
Why cant you publish interim results and state they are interim?
You could place a disclaimer beneath the results stating they aren't yet conclusive.
Reactions: 2 people
Mark42
Patron
UK
Other
PV Panel War: Sanyo v. Hengji. The ultimate side-by-side long-term, real-world test.
Mark42,
danesol,
