T
trev
Just the line?
remove the red cable from the henley, job done
To LEX
If you involve the DNO then they may require a BS7671 cert or other certificate of safety/compliance before reconnecting.
I'm hoping that you have a full set of calibrated test equipment so you can check your new consumer unit?
I am also hoping that you have (or will) notify the local authority before starting work, or are you a registered electrician?.
well....from what i remember there was a hoo ha over this....the DNO didn`t like the idea of built-in iso`s as they stood to lose money.....shameful really.....elf n sayfti anyone?...Do these new meters not have the built in isolator, I can see a small black hole top right but can't tell what it is, if there's a slotted screw in there a ninety degree turn isolates it.
Personally I would just take the cables out of the henleys.
I have a fluke for testing. I'm registered with JIB but haven't told the local authority anything just yet. I've spoken to the DNO, they are coming out to fit a proper isolator so this issue won't come up again.
Hmm, what sort of Fluke meter will that be then.
Does it have Insulation Resistance, low ohm and RCD testing facilities?
also
Does JIB allow you to self certify and notify installations in accordance with Part P? I wasn't aware of that little loophole....
not commissioning big Ben!
