G
gvelec
Hi all,
I'm new here, so please go easy :yes:. Would appreciate some assistance though.
I've just been around to my mums and go a little buzzing type shock from the toaster. I only had my electrical testing screwdriver with me as i'm miles away from home. The screws are indeed live for this socket as well as for a neighbouring socket. Verified that it is a ring from the DU, and have killed the circuit.
I've checked the earth connections to the sockets and they are fine. Any ideas on how i can test and fix this up in quick time with no equipment. I know that really should have been carrying my Kewteck multifunction :6:.
you need to do a thorough test procedure. R1+R2 to start with. check also the main equipotential bonding to gas and water. check to see if you have a voltage N/E. , Ze, Zs, etc., etc.
I think you're going to need more test equipment than a neon screwdriver, unless it doubles up as a magic wand :grin:
I only had my electrical testing screwdriver with me.
frightening........
I know. Frightening! But travelled 150miles for the weekend. Didn't think I'd need my mf. I may well make a trip back tomorrow to pick it up. Can't leave it like this. Nor can I do a temp job until next week.
Thanks fellas
I think he's saying it's a fault on the socket where the toaster plugged in, not the toaster itself.
Yeah, but if he's only got an 'electrical testing screw driver' with him, buying a new toaster is about the only thing that can be done.
Check it out properley with a real tester, the neon screwdriver is probably lieing to you...
Post up your location also. one of us might be near enough to come and give you a hand. With a tester
