Excellent dude. I believe you.
The chase scene through the asteroid field is the best moment ever for me, to quote Solo again
"never tell me the odds"
And the music was incredible
If you post the area of london you are in you may get a couple of guys on here local to you willing to give a second opinion, and if you happen to have a few "work colleagues " there you might get all of us turn up:fuk2:
Best scene was it,scenes are better later films you watch
Epic Star wars is,melting in river of fire was Vador good to see
When Vador had Luke snookered
"I have you now"
"Use the rest Luke,use the rest"
That ones a bit before my time! Trust me though, it's not as glamorous as some people think!
Could be a can of worms,
You are not obligated to split the ring circuit into 2, if ones ok and not overloaded now it will most likely carry on being fine on a new fuseboard. As with lights.
It does look a proper mess mind. Could have duff wiring, green goo and any multitude of things.
IMO you are best paying for an EICR (test and inspection) then go from there.
I'm sure there someone on here local to you that can do it a reasonable price.
With regards to earthing, looks like it could be TT or possibly TNS with that incoming 1 1/2" conduit used as an earth.
That black cable is the earth, very common around here to see black used in the early sixties.
Replacing consumer unit - advice please !
Johnlondon,
somersetsparks,
