S
screech
Heys guys.
After a bit of advice regarding off peak heating really.
I recently helped my brother with his flat that he bought and done a complete strip out and re-new everything!
Before we got in there, there was just one storage heater in the lounge. He asked for one in each room, obviously.
So i wired a 20a circuit into each room to an off peak CU.
He's now moved in and the temp. has dropped, he's decided its time to pay out and get the heaters.
We originally agreed storage heaters, but i do wonder if theres any different/better alternatives available...?
Cheers
It would have to be something that could be energised overnight on cheap rate, retain energy put into it and discharge it later on during the day;
something exactly like a ,,,,,,
So No, for overnight off peak storage, just variations in quality of Storage heaters.
Above but I usually advice the main/ lounge one to be a duo with a on peak fan heater just in case your previous nights guess work was out :)
[h=1]Ok thanks, so storage it will be, as planned.
So i've just started looking, and already confused! I'll admit, i've not really touched on heating before, apart from changing like for like in council houses a few years ago!
So for example i see this one, but with 3 variations and 3 different prices:
0.85kw Manual Storage Heater In White - 1 Rate
0.85kw Manual Storage Heater In White - 2 to 4 Rate
0.85kw Manual Storage Heater In White - 5+ Rate[/h]Whats the 'rate' mean? It seems 1 rate is most expensive where 5+ is the cheaper...
Cheers
This is just the first one i've started looking for, its just for the 2nd bedroom, which is literally, a box room.
Cheers
Price for buying heater 1 at a time, or 2 to 4, or 5.
Discount for quantity.
Elnur SH6M 0.85kw Manual Storage Heater In White - 1 Rate
there are other alternatives to off peak,some interesting looking radiators by a forum sponsor,www.economy-radiators.com,i have never used them but they seem a viable alternative and you can change the off peak c.u to peak if the peak loading/diversity allows.other then that go onto tlc direct and they have all the data and trade prices on various heaters to give you an idea.
i'd go for panel htrs c/w timer in bedrooms - then you don't have to have the heater on all night, giving out heat whilst you're trying to sleep! timed for 30 mins before getting up and going to bed.
also never less than 1.7kw in rooms other than bathrooms.
and yes, fan assisted with convector in lounge
screech,
maffa ent,
