Hang on folks, how does a broken test lead on a meter cause a two way switch circuit NOT to work? Axel, I have tried to help, can you please explain what the fault was (in simple terms for a dummie like me!)
i read it as it wasn't the test leads that were broke but one of the cores in the lighting circuit.
The test meter was registering continuity through the broken core however it wasn't continuous.
Thus broken meter, and broken circuit.
Sent from my GT-I9300 using Tapatalk 2
But the test meter would be registering continuity before it was even connected if that was the case??
ok. I have had broken cores in a brand new cable too. Sounds unbelievable but it does happen. Bit of a head scratcher at the time but break down the circuit and test and fault found. Bit strange cable giving continuity on a broken core though. Especially as the circuit WORKED WHEN PUT ON ANOTHER SWITCH!
Dunno about you guys, but I use a Fluke T5-1000 with built in clamp meter for general belling out, voltage testing ect...
The FIRST thing I do is switch it on, and select the required function - Voltage/ current/ continuity.
The SECOND thing i do if checking for continuity is join the bloody leads together to check it works! FFS 4 sparks couldn't get that right?
What's that funny smell?
Also the t120 isn't really the best thing to be belling out with, as it screams its ---- off if you hold one tip in each hand.
Has someone let one rip in here, or is it the BS starting to pong a bit? :biggrin5:
9 pages on a poxy domestic lighting fault - awesome lol.
only 2 pages short of the epic "9.5kw shower on 6mm" thread.
anyone else feel a tad embarassed that this fault wasnt nailed within 2 pages lol.
OMG i missed the "9.5kw shower on 6mm" When was that posted??
I agree with ackbarthestar do a wiring diagram you may find the problem is staring you in the face. Works for me.
It was 2nd fixed incorrectly and let that be the end of it
Hopefully you have learnt two things from this
1. How to 2nd fix 2 way lighting
2. Not to come on here asking how to work out a fault that was never there and become abusive when you get sussed and your pantys pulled down
I have been using fluke testers identical to that for 10yrs, never let me down once why......... Because they are used correctly
