S
sl1210
Hi guys,
Went to see a job yesterday where the whole flat has underfloor heating, which has packed up and now they want a quote to replace this system with electric wall hung heaters. Because of the size of the property I reckon it will need at least 5 heaters. The property currently has 2 ring circuits, 1 for the kitchen/dining area and 1 for the rest of the flat.
1 of the five heaters I can spur of the kitchen ring, but not sure where to take the supply for the other 4 as I'm sure the load would be too much to have 4 electric heaters on the other 32a ring, with each one spurred off the nearest available socket.
Now the current underfloor heating seems to spread on 3 individual circuits in the consumer unit on 16a mcbs, but the supply doesn't seem to go to spurs for each thermostat, I think it goes straight to the stats. There are currently 5 underfloor heating stats. I think they are all connected to some kind of relay in the consumer unit, which is always making some sort of clicking noise when I tried testing the underfloor heating.
Is there any way possible to put these on the ring, or would I need to break down the load with wherever these 16a feeds are going too.
Cheers
Cheers
