Discuss Pyro Cable Tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
why dont the O/P seperate each leg.....and test em individually rather than just goin round...n round...n round....
and stop using `extention leads` to test with...or any other crappy lashups like that....
Was just about to suggest that Glenn, it's the only way. Work your way round the circuit leg by leg and you'll find your problem. You've probably gone round and round in circles and are now in the process of disappearing up your own backside, we've all been there and done it. As others have said, it's bar nigh impossible for 4 lengths of pyro to all go down at the same time.
i am still guessing that the problem has been caused by someone not knowing what they were doing and they have tried to tighten the pots a very big no no as we who know knows. and no i am not 50 yet lol but getting there faster every year!!!!!
Or another possibility is its a 4 core pyro and its just one length that is damaged and he is just not explaining it very well ????
theres no shame in admitting you have no experience in pyro , its a dying skill that isnt taught anymore as its only used in a handful of building types.
i'm old enough to have been at college when it was still a practiced technique but its been over 6 years since i did any work on micc and i dont have , nor intend buying , the expensive tools to work with the stuff , and as such i avoid it like the plague.
i'll take fp200 any day as i know i can fix it in 2 minutes flat rather than fanny about for hours with blow torches and sealing putty.
Yeah but when you get some of the cantankerous posters on this forum combined with the fact that most sparkies are not overly eloquent with the typed word you can see why people are reticent to post or don't explain themselves as well as needed, and then you go around in circles trying to fathom out the fault/issue.
I still maintain prayer is you greatest weapon in resolving this problem...
why ? what happened there spin ?
Following some rather heated arguments between contractors and subcontractors about hours and rates of pay.
It was discovered that a number of cables no longer had end to end continuity.
This was discovered to be due to a number of cables having been accidently cut through along their lengths. Some of the cables being cut through in a number of places.
Fortunately after some negotiation and a willingness of the workforce to work overtime, everything was put right, and the line was opened in time for the millennium.
I believe the overspend was somthing in the region of £400 million (not all down to the damaged cables).
Or divine intervention
While there a few on this board admitting they have no experience with Pyro it begs the question as to why you would take on a job where it is installed when you are out of your depth with it
As for tools as it has already been said there is a lot of ways of making a Pyro off without all the branded tools
And as far as FP200 and similar goes this is the most wrongly installed cable I have ever seen especially when installed for fire alarms. The number of fire alarms that don't comply with BS5839-1 all because somebody couldn't be ????? getting the clipping right for peoples safety this cable should be banned on fire alarms
tony mc i've got a megger mft1710 and only IR tests at 250v and 500v, so to answer your question no it doesn't test at 1000v.
Obviously, a 17th ed instrument, get a proper one an '18th ed' Claire insulation tester, delivers 5kV and knocks the little buggers off the end of the terminals......
TBH, it used to be, and still is, standard practice to use 1kV to remove illegal immigrants from the ends of pyro terminations, just before potting comences.
Reply to Pyro Cable Tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
