dave30
hello im changing a consumer unit from old style bs3036 semi enclosed fuses the fuse ratting are as follows 5 15 30 15 30 30 amp
if i was replacing with bs 60898 mcb would i use the following sizes 6 16 32 16 32 32 amp
and will this be ok taking into account the size of the conductors of each circuit and the max carrying capacities being
1.5 mm csa for 5 amp
2.5 mm csa for 15 amp
and 2.5 mm csa for the 30 amp two of witch are radial and one is a ring
all instaled in in method 102
thanks again for all your help
