L
loz
It appears that the SWA is used for the cpc to the external dist box and to he van hook ups, they are glanded but not earth link from banjo to an earth bar so it only takes 1 of these to come loose and if its the 1st 1 then the entire system has no earth.
having worked in alot of these panels and also knowing the company that built that panel, the earth fly leads arent required as all the glands will be glanded into a solid brass plate, so there's no need for banjos or fly leads, this is common practice in the caravan park industry, usually there is a 16mm cpc bolted to the plate inside the black shroud, but this may be missing, but worth checking. loz
