J
Jeansie
Hi,
I'm new to this forum, but it seemed like a good place to find out why my voltage tester (screwdriver type) basically just exploded when I tested it on a mains voltage supply (back-box of a fused spur switch). I was trying to check whether the fused spur is part of the main loop (it looks like it is - it has 2 twin and earth cables feeding into one of the "input" set of the live, neutral and earth terminals, and one twin and earth feeding from the output to a junction box which isn't feeding anything)
Hopefully you can see from the attachment what it did to the voltage tester
None of the power supply has failed for any of the sockets in the house
If anyone has any ideas why this happened please let me know.
it probably happened because you went short circuit with `it`....
and they are an `it` n all.......
how dare you come in here and start waving such a nasty piece of work in front of us....lol..
glad you did actually as this is clear evidence of just how grotesque these artefacts to incompetance really are....
throw em, break em, smash em ......wherever you find em.....
So... I touched it on something I shoudn't have whilst it was still in contact with the live terminal? I've been using it to test the means voltage this way for weeks and this hasn't happened before. What did I do wrong this time?
You've probably hit the side of the tip on neutral or earth terminal while the end was on the live.
can you take a closer picture of just the very tip?
Shorted, lucky you never got eye injury, throw it in the bin/recycling and wouldn't buy another one.......you need some proper test equipment, and a volt stick.....would you like a volt stick for your toolbelt? I can post you one in the mail for free , I have a few spare....
On some accessories the earth bar is right in front of the live terminal....so an uninsulated tip of a screwdriver can short out the live and earth.....it didnt 'explode'...you caused a dead short between L and E. If you look at the tip of your screwdriver you can see the two contact points.Potentially several hundred amps would have flowed through such a short instantaneously.
Get yourself an approved set of voltage probes with insulated tips.
If the fuse/mcb/RCD or whatever didnt operate I'd be checking the correct type and rating for the circuit is installed at the CU.
Cheers for all your replies.
Electric Will: See attached picture
Grantr: Are the volt sticks the non-contact ones which either glow/buzz if they are near a live feed
wirepuller: DSC_0122.jpgI think the entire mains is on the same circuit and nothing has stopped working, so does this mean the fuse must still be fine? The house has one of the old style plug in fuse boxes - what rating should the mains (sockets) fuse be?
these things use your body to complete a circuit, jeansie. you're putting your faith and wellbeing in the resistor that is fitted in the screwdriver. bin it and get a volt stick.
no offence you dont know what your talking about , ive been there now looking back on my old posts, but can see your learning or egarness to learn somewhere in above posts... get yourself a proper voltage tester..£30 if you plan to work as electrician i just gave one away too or you could of had it.
we all have neons and are very careful and know when to use them. which some/most people will say never as they arnt 100% safe
If you had the tip on the live a lot of new socket plates have the earth very close and I think as others have said you shorted it out I would get a 2 pole tester or a non contact volt stick at least a bit safer.
some volt sticks are rated from 110v to 230v so effectively they saying might not pick up 90v.
I'd never trust a volt stick, however if you do use one get 2, and stick them both near the cable, you may find one won't light at all, very unreliable, my post above was just for fun, please buy a proper tester.
I am rather worried that you say "Tested it" this sounds remarkably like a drunking ebay purchase which you have been eager to play with when it arrives a week later from China
I have loads of them.. The only thing I think these are good for is the terminals on junction box's
Voltage tester.... The only thing between you and electric shock is a resistor...
mines a ck one and cost 3.50... but all chat about these being bad for health and they seem to be everywhere for sale even the pound shop with connectors and pvc tape all in one bag
