Your original post was saying you are swapping a 3gang switch (or as you call it a 3W) and replacing with a 2gang switch ( or as you call it a 2W) but your photo is of a 2 gang so I'm guessing this is what you have done which IMO is a disgrace
I said removing a 3w switch ie 2 switches and light fitting of circuit with a 2w ie 1 switch and light fitting so removing 1 of the switches and the other switch being replace with a 2w 2g switch. As 1 gang will control hall light and other outside light. Im not sure what your getting at ?
He's getting at the fact that you are a DIY chancer.
No, you have lost me, it would help if you use the correct terminology a 3w switch is a 3way i.e. intermediate switch not 2 switches and what had a light fitting got to do with it ?
- - - Updated - - -
I am a GCH engineer so do have experience with electrics but obviously not at the level you are at. Thanks for your helpful information .
I agree, when I saw the box I was concerned over how many wires were with in and the bare cores. This was carried out by the guys who refurbished bathroom as the top wire powers fan. Anyway as I have said the box has been tidied and made safe. I am not a Diyer but also not a spark hence the reason I was just looking for a bit of advice and was under the impression that's was what a forum was for. I'd understand the resistance to help if I was in the arms/professional page or if I was intending to rewire a house but all I am doing is changing a light switch.
It may be only changing a lightswitch to you but people have died doing less.
I've just seen the piccies of this "job".
It's an absolute abortion !!
Give up now bonny lad ....... sparking clearly is not for you !!!
