there is one, better still if the fan manufactures could build a inline fuse holder or thermal cut out to stop all this booox
i heard of a cu with a 3amp mcb dedicated to supplying extractors?
We have been through this with the niceic and we now have to code an unfused bathroom fan as a code 2
er , no you dont cos its complete nonsense lol.
so 99% of properties will now fail your EICR's then ?
that is truely money grabbing , regs bending , mind numbing baloney.
If that's a multiple choice question I'll go with answer 'c' - mind numbing baloney
Edit
I might have been a little hasty, money grabbing also sounds possible.....bah I hate multiple choice...
We have been through this with the niceic and we now have to code an unfused bathroom fan as a code 2, we've been doing this for a couple of years now and to be honest we come across it all the time, but yes we've been through this a few times on here manufactures instructions should be followed at all times and yes they do state 3 amp fuse for fans
Not something our NICEIC assessor has instructed us....and he goes through my EICR's with a microscope.
Mine downstairs is fed from a fused spur with a 3a fuse?
Point taken on the customer changing it though,it could have blown once or twice then the guy stuck a 10a fuse in it as:
A) it was all he had
b) it stopped the missus moaning about the condensation in the babathrooms
c) all of the above.
I have never heared of this I know your suppose to put a triple pole isolator outside of the bathroom but how you gonna fuse it down as well go straight from the triple pole isolator to the fuse spur it will look **** above your bathroom door
I was told by my nic inspector that if we use fans with built in thermal overload protection you dont have to fuse down bellow 6A ??????????:smartass2:
so NIC now also overrule any manufacturers instructions, they really are the font of all electrical knowledge now aren't they.
you could use a dual box to mount the 2 plates, or as a previous poster said there maybye a triple pole switch with an inbuilt fuse available
Totally agree with you, how do you fuse a fan at 3a which has a L/SWL from the bathroom light ? The last one I installed I wired the supply to the bathroom light via a FCU to protect both fan L and SWL.
btw what type of fan are we discussing? one of those cheap £12- ones or something like a greendale
also if you energize a bathroom fan then jam the impellar does it get overheated and catch fire?
Hmmmm, so the ECA are making a bit of a push regarding 134.1.1 ? This presumably includes torquing of terminals in distribution boards ?
In other totally unrelated news, I see the ECA have started selling torque screwdriver sets.
