We could also try and instal a rcd socket, and chuck a 3A fuse in a plug and flex to the fan. Should more or less comply. Lol
In all i have never done a 3A fuse down on a bathroom fan, but what was the prosecutions findings and what was the fine ?? I know he didnt mention the company, but normally you get a tidbit of how much etc.
i think most fans' instructions call for just the perm. L to be fused, not the s/l.
Now you mention it my NICEIC assessor was banging on about fusing fans at my last assessment. When he asked me what I did, I just said I followed BS7671 and manufacturers instructions. He accepted that and then mentioned the fused switches, others have also highlighted.
Time to invest in 3amp MCBs i think, although if everyone did that I guess they would change the game and insist on 1amp fuses to make sure they've got another get out of claim card
I always fuse down to 3a where specified in the instructions. Many actually call for local DP isolation. Easiest way to do this IS to fuse down the whole of the bathroom lights, thus encompassing the switched and perm lives. Nobody can argue then. It's a ballache if the fuse blows of course, cos it takes out the lights as well......but hey ho. The fusing down is a bit of a mystery to me, cos the circuit is protected at 6a anyway! And would a 3a fuse blow before a 6a MCB operated?
A total load of rubbish! If you stall one of them tiny fan motors, there's no way it could cause enough over current to start a fire Come on get real!
Just had a quick scout on the good old google, apparantly MK make a 3A MCB? really? i never knew 3Amp MCB's even existed, where the F have i been living all this time!
If it is true about fans needing 3A, then if its a new build you could take it from its own circuit...i fear for this though, wont be long before literally everything will have its own dedicated circuit.
just looked on the IET forums, and low and behold, its mentioned on there, via an NIC inspection, but from 12 months ago, and story says its from recent years, seems like a bit of NIC fore play before they s***w you
IET Forums - Fuse protection for extraction fans
u only had to ask lol
I honestly never ever new that 3A MCB's existed hahaha oh my days.
Isit just MK that make them?
