R
Robert Turnbull
True 2 fuses lol
How would that work though?....there's two lives.
Sorry?On that note even a fused spur would be useless unless you fuse down the lighting for the room before you do the switching.
If you've got a 3 core t+e a fused spur isn't going to help is it. As you can't fuse down live and switch liveSorry?On that note even a fused spur would be useless unless you fuse down the lighting for the room before you do the switching.
Just had a quick scout on the good old google, apparantly MK make a 3A MCB? really? i never knew 3Amp MCB's even existed, where the F have i been living all this time!
If it is true about fans needing 3A, then if its a new build you could take it from its own circuit...i fear for this though, wont be long before literally everything will have its own dedicated circuit.
