Or why don't they just switch the breaker off, rather than at the isolator, if in doubt get an electrician in, but even a voltage tester as mentioned before would be better than a volt stick alone. They would need a proving unit to prove the volt stick is working correctly.
I agree, but I think I would be locking it off as well - just to be a bit safer.
As for our Friend the OP having to write this "Standard Operations Sheet", I think I would politely decline to do this UNLESS the company instructs me in writing and adds that in the event of an accident I will in no way be blamed for it and have it signed by the boss of the company. Even then, I wouldn't be entirely comfortable with it.
What's this I'm signing?
Oh don't worry about that, it won't concern you (until things go wrong. Then we'll have it coppied and sent to the corroners court).
I haven't read all of the answers but I'd be more inclined to turn the shower on, leave it running and flick the breaker off, lock it off and then switch the double pole isolator.
Obviously without test gear none of this would be done anyway and I would be telling the company MD to sign it...
Probably right , but if they aint got the voltage tester they not likely to have a lock either :biggrin:
i have getting the answer I'm looking for - I'm not writing a procedure. Will let someone else do it, in a couple of weeks time he will have totally forgot that he asked me.
Cheers.
Haha...problem solved hours ago!
Just keep on forgetting to do it.
You'd be best to write the correct safe isolation and locking of procedures involved nothing less!
Testing for dead with a volt stick ? I did that once. I do miss those side cutters.
Anything you sign your name to has got to refer to proper safe isolation procedure and be carried out with proper approved testers. Anything less and your arse is hanging out in the breeze imho.
May be better checking for a pulse....after isolation, of course.
Why doesn't the electrician go too when plumbers turn up to change the shower he/she can isolate for them correctly then revisit to do the test. Simples
Well it's that 15mm water pipe innit ..... can't have electricians touching that mate .. that's the plumber's job!!
That will be because you don't understand the different compression (or sealing) properties between a copper olive and a brass olive. Is the brass olive one belt with the apprentices head against the end of the spanner to seal and the copper olive two belts with the apprentices head against the end of the spanner to seal?
Or the other way round?
See the issue?? Its highly technical and you need to be able to read grunt to be able to understand the plumbers regs. (and find a copy!!).
(Just realised I'm quoting Geordie who, may, have a subliminal understanding of grunt!! :smilielol5::icon10:)
