o oh.....flush the toilet and the light comes on.....
I'm not letting a plumber anywhere near my new TechnoToilet!
That will be because you don't understand the different compression (or sealing) properties between a copper olive and a brass olive. Is the brass olive one belt with the apprentices head against the end of the spanner to seal and the copper olive two belts with the apprentices head against the end of the spanner to seal?
Or the other way round?
See the issue?? Its highly technical and you need to be able to read grunt to be able to understand the plumbers regs. (and find a copy!!).
(Just realised I'm quoting Geordie who, may, have a subliminal understanding of grunt!! :smilielol5::icon10:)
And who are you calling a grunt????
to OP
its a blame culture, don't put yourself in the firing line.
sounds like your company is setting up for a scapegoat
just reading the title, when are we going to have electric showers replacing plumbers?
To Serious a note here, This is under Bad Practice for whoever is involved.
The Electrician Should Isolate the Shower From the DB or CU meaning remove cable from the Fuse, before the plumber gets his nutty hands on it, its all stated in the Regs, Isolate, a volt pen is a no no a Proper Volt tester (multimeter etc) should always be used, bugger me what kind of forum is this..... next Lick it to test that works..
I would remind your employer that company directors have responsibilities as well. If they think they are pulling a flanker by pushing the responsibility onto you, they are sadly mistaken.
correct having an un qualified person work on the equipment with out proper equipment is plainly stupid
our guys at work all have these kits
Breaker Lockout Sampler Pouch With Brady Safety Padlocks & Tags - 99296 - BRADY
there is also larger kits with the large plug isolators for 3 phase plugs like the nema 14-60p (shown here)
NEMA Plug & Receptacle Configurations Reference Chart (Straight Blade)
to the op do not sign off on this (those weasels are just trying to avoid responsibility)
