M
Megavolt
Come on then put us out of are misery
The true answer is 20 .... the world follows the BODMAS or PEMDAS systems which give same answer..
Brackets off,Devision,multiplication,addition,subtraction.
so no brackets to worry about then
4x4 + 4x4 +4 -4x4
16 + 16 +4 -16 =20
The confusion arises because the uk messed up the teaching system and dropped the enphasis of BODMAS and simplified it by always using brackets to show order, this meant that we got so used to brackets we forgot about the BODMAS rule and when we see a sum without brackets we assume its a progressive sum left to right but this is incorrect, when no brackets are present BODMAS takes over and should still be used once any brackets you have have been removed.
Most of us were failed by teachings and even modern maths teachers are having to be re-educated about it and enphasise it more as the rest of the world uses this or similar methods.
