Discuss operating fans through dimmers in the UK Electrical Forum area at ElectriciansForums.net
J
jmc1683
recently finished 1st fixing of large house, wired bathrooms usual way, switch outside the door and fan isolator up high, fan switched to come on with light, usual way, now they tell me they want dimmers on bathroom lights, if I put dimmer in now it will be operating fan also, unless of course you isolate the fan when using dimmer but this is not practical solution for average person, any suggestions?
I must be unusual,because I never have them switched by the light,why have the need for light to become the control for ventilation,it never made sense to me, so I never ever do it that way
If the customer did happen to have that method in mind,it does not take long to explain the error of their ways
guess you could use a humidity sensor?
also for some fans could be wrong but [FONT=helvetica, arial, sans-serif]the s/l into the fan is only a trigger for the timer?[/FONT]
most fans will work fine with dimmers.
they usually start up with the dimmer even on its lowest setting.
some are more sensitive than others.
some only come on once the dimmer is at full brightness
Agree, very wasteful for lights to have to be on when fan on. Daz
Reply to operating fans through dimmers in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Evening all.... My son is 14, he seems to be taking ultra long baths and showers and the bath/shower room is drenched afterwards. I have just...
8K
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
9K
Hi, I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside. The first dimmer switch controls the LEDs and...
