S
stuartcourt
Hi Just replaced 6 GU1O (incandescent) lamps with 4.5 watt L.E.Ds and replaced Dimmer for Aurora dimmer (L.E.D compatible) does not seem to be as liquid as GU10s used to be although ok. My next customer is an ---- mother and wanted to know if anyone knows of better (dimmer)product for 8 x 6 watt GU10s cheers.
Hi cheers guys mega man lamps and same here with Aurora I will give yours a try
I've just put in the same. 8 x 6w on an Aurora dimmer and all works fine until you dim them low and they start to flicker. A slow flicker, more pulsing. Will try the ksr module if its recommended.
