P
Paul.M
What is missing from all of these pictures? All taken at the same job.
1. This is the main incoming isolation board:-
2. DB 1:-
3. DB 2:-
4. What's the fault in this picture of the main earth terminal (earth bar for the full installation)?
1. switch cover 2/3 switches
4. conductor should be 10mm, cable damage
Correct on pic 2 & 3 there is no isolation switches therefore no way to turn off the full board/s.
Is there any damage that you can see in picture 4????
thats what i thought either that or black insulation tape also it's solid green should be 30/70 yellow green, white earth cable as well?
Visual Fault Find # 2
Electrical Course Trainees Only
Paul.M,
Sparky_Steve,
