Just a little query.....i was told recently that you can have skts @ a higher than 1200mm if it is for a specific purpose ie wall mounted tv or above tall feezer etc. I got pulled up on my own house (first fix stage) by building inspector that I had put single skt too high for wall mounted tv. To overcome issue quickly I put switch fuse spur @ 450mm which in-turn controlled the single socket.
I'm in the progress of doing the 2395....Guy taking the course and some of the other sparky's said that the building inspector was wrong. Is there any regs to that effect?
you are right. BI was wrong.
Typical building inspector, no common sense and sees a socket high up on the wall and says you can't have that! Even though it's not a new build! Love proving the idiots wrong.
Hi mate get a copy of elecys guide to building regs or a copy of part M and stuff it under his nose to read and tell him to get back to you when he has
Burnt Fingers,
brucelee,
