daz240
Hi
Over the past few days my hot water tank hasnt been heating up the way it should and in the morning we have no hot water.
Im in a flat with no gas so i have an electric immersion tank with two heaters (Overnight and boost)
i know that the thermostats are normally the problem and after listening to the tank at night when it ticks over it sounds like there is hissing coming from the heater but not as much as there normally is and not as much the the boost heater.
So today i was going to swap round the thermostats and see how it went tonight. On taking the covers off on both of the heater it seems like the wire positions on the thermostat are different. They are both the same thermo (Backer BT7) there are two wire locations one for the brown wire and another for a white wire that attaches to the heater. On the two i have they are both wired differently, they have both worked for the last two years.
So my question is doesnt matter where each of the two wires are connected to the thermostat???
Cant find anywhere online that will tell me?
Hi,
Are you saying one of the elements is still operational and the other has failed, or both? Before I changed the stats over I would be first checking the element to see if that is at fault. Is the MCB still in or has it tripped? Do you have the means to check the element?
Regards.
My over night heater is the one that doesnt seem to be working correctly.
it seems like the heater has life as i can hear very faint hissing when my electricty flicks over to the cheap rate over night.
The job seems simple enough i took a picture of both of the thermostates then proceeded to take them both out. When i tried to fit the lower one into the bottom i saw that on each picture the wiring was different. So i put it all back and thought i would do some research.
One thing i did see that was very odd - As i said the thermostates were both exactly the same (backer BT7- with same labels) appart from the point that slides into the tank(heater). One was like a spear or a golf tee and the other seemed to have been flattered at the end on two sides making it an X shape. This X shapes seemed to hinder the thermostate from sliding into the lower over night space.
Yep also to confirm all power has been turned off at the fuse box and is safe.
Changing the thermostate looks simple enough - anything more then i wouldnt attempt it.
just different age of stats bate the bottom one has probably been replaced before as it gets used more. It sounds more like your element could be going TBH but your doing the right thing checking the stats first. Do you have a multimeter
no means to check the element - but it seems to hiss when the power flicks over to cheap rate. But it doesnt hiss as much as the working one above when that is turned on.
i had the element changed maybe a year or 2 ago.
Be careful here. Some stats have the safety cutout built-in and some require a separate unit. I realise that it seems a simple job, but you really should get a local qualified electrician in to sort this for you. If you live in a hard water area then it could even be an element scaled up and operating poorly. The only way to know for sure is with proper diagnostics. A good electrician will also test your earth loop impedance at the element to ensure the system is all connected properly, along with the RCD protection if you have any.
I agree with the others. Usually - water boiling, thermostat - water cold, heater element.
As Somerset says, safe isolate, disconnect the wires from the element, test the resistance of the element with your multimeter. Don't test with the wires in place.
Remember - you are on an ELECTRICIAN's forum, we have a right to expect that your understand how to safe isolate etc.
Laurie
Hi, I have been away a lot recently so I have not had a chance to do anything with the water heater. But just before I went away my new thermostat got delivered. It is slighty different to the one I have in place already but probably only because the temperatures are not printed on the top. So my question again is really... does it matter on this one where I put the wires into it. I have notice on the top that there are plus and minus signs but im guess that is just for temperature and not +/- to do with the wire placement. Sorry to be a pain but I just just want to cause myself more problems. Let me know what you think. Thanks
new el.jpgHere is the picture of the new thermostat
Here is a picture of the old one in place
If this doesnt work i will have to call someone out (All my fuse box will be turned OFF while im doing it)
Just need an answer about wires on this one
- - - Updated - - -
Just put a piture of the old stat in place on the tank - dont know if there is a cut out ....!?
The reason behind the new safety cutout is that people have died due to tanks boiling over and venting back into the plastic header tank, which subsequently melts and dumps gallons of scalding water on those below.
It's up to you if you want to use a standard stat to test your setup. How are you planning to test your earth loop impedance at the element, incidentally?
http://www.tlc-direct.co.uk/Products/IHST7slashC.html also has the safety.
Dont be mean! lol Hes a DIYer. I would say as he is just doing a like for like replacement and not touching the earth connection it isnt necessary to test it, obviously an electrician would but hey ho, it won't be any worse then it already was
Im just trying to save myself from spending out about £100 for some guy to spend two minutes replacing the stat and finding that my element is perfectly ok
I'm not rich enough to pour money into someone elses pocket for a simple job of two wires!!?
Sometimes common sense can save people alot of money.....
somerset - by looking at the new one i have bought does it matter which side the wires go on? im guessing the plus and minus symbold are for temperature and not +/- wires.
If this works i will buy one with saftey cut out.. just dont want to waste anymore money if it doesnt
Obviously not that simple, as you weren't aware of the safety cutout, and you are asking for help from professionals for free.
If you saw the dangerous situations which we see every day due to people trying to save money, you might understand why we ask so many questions.
I am aware that there are two types of cut off methods one on the thermostat and one that can be wired into the element This is information i got from reading about immersion heating elements around the internet.
As i only had my element changed a few years ago i would of thought that i had quite a newer setup from what was there before. As i remember the previous stat on there have a reset button on the top for saftey cut out.
i understand where you are coming from and i dont claim to know much about this but im willing to sit up for hours at a times reading guides and gathering information so that i can fix it myself. As people have said above... changing a stat isnt very hard. From a saftey point of view we have all seen the programs where people get someone in and they have completly botched the job and a few months down the line you are paying out again. I trust myself, i do as much research as possible and if i feel that i can fix the problem i will try with saftey in mind!
im asking help from professionals as you are a member of a forum and thats what people normally do on forums.
Your quote in the Signature doesnt help....... :)
I respect people who do their research. What some of us are trained to do however, is deal with things out of the ordinary which often present themselves. These things may not be obvious to the untrained eye.
Regarding the forum...it is an electricians forum, not a DIY one.
I offered the initial advice as I didn't want you fitting the wrong stat, and it was obvious you weren't going to get a professional in. Electrics are my bread and butter, but I still want people to be safe, even if they refuse to pay for a trained and qualified person to do that job.
My signature....tongue in cheek. I do loads for free when people genuinely can't afford very much. That's why I will always be poor. :)
Electric Immersion Tank + Thermostat
daz240,
Guitarist,
