M
Marvo
I'm not sure I qualify as a SAFA, I was born on Gibraltar and grew up mostly in W GermanyThats a bit rich coming from a SAFA whose a muck spreader ...
@Jay Sparks
Easier to test at switch yes, but that is not the point that the test should be made at, and some of the projects I have worked on (and run lol) have requested complete test certificates Including Neutral readings which Cannot be done correctly if it is 'spider'd' off of every light switch rather than going around the lights.
Good answer O, BUT....
1, 3 & 4...we don't design and install electrical systems for untrained people to mess around with.
2, use a deeper box!
Re the rest, can't comment of bigger installs myself!
I think this is a case of we'll agree to disagree!![]()
*edit* It might look like we're in cahoots but I didn't copy my answers from Archie, honest.
- Please see replies in red
Putting all opinions of which is easier etc, the reason I give above Is valid as it does Not allow for the furthest (longest run) Neutral to be at light number 5 for example, when the circuit has 15 lights on it, as light 15 should be the end of line for the Neutral conductor as this is the end of line (longest run) for the Line and CPC as well.
I love Gib!
After being nearly raped and robbed in Morocco...
You sound almost disappointed![]()
Sheesh what kind a debate do we have here.
i see no problem personally in a neutral at the switch.
all the problems that outspoken highlighted can be attributed to the loop in at light method also... So whats the better system then?
ill tell you .whatever system is the easiest.
wiring in containment in singles yes I agree ns at lights feeds at switches
but we are talking twin here.
even a lot of new commercial stuff is done in lsf t&e and I'll bet you the neutrals will be at the switch most of the time.
Is it just me that is a bit disturbed that the op is doing his am2 and needs to ask how to wire a basic lighting circuit?
my am2 lighting was in steel conduit if I can mind that far back correctly
Why not?
The last switch with the circuit will be the furthest point, and if one wanted to test it further still, put the switch in the on position and test at the last fitting.
Right ok I am and always have been in favour of a 3 plate wiring system when I am unfortunate enough to have to use T&E.
So to all those slating neutrals at the switches can any of you actually give a reg number that this contravenes.
Given the right circumstances as previously stated eg downlights I can't see a problem.
What do you mean 'IF'?????????????? "Testing should be carried out at the furthest point of the circuit"
Maybe the problem here is that just because it is T+E we are talking about you all seem to think it has to be in a house?
The OP did not say it was for a house, so it could be anywhere, and that can and does include a system wired in T+E that can have the switch for lights many many many metres away, and also in a different part of the building.
Regardless of the OP's initial questions though, the neutral conductor "should not" spidewr off, t off, call it whatever you wish to, in a correctly installed lighting circuit. Could you post the reg that states this?
If you cannot understand that, then you need to do some reading and swat up on your regs and wiring standards.
Just for your information, the only time when it is allowable to Not test at the fitting is if said fitting(s) are installed using a flexible/manufactured lighting system/installation etc...... IE a lighting control pack that uses plug in modules for the actual light fittings to connect to. Also, could you post a reg for this?
