S
Surefire
Someone once told me this is bad practice but I cant remember why. Could anyone remind me?
i believe he is on about an old practice of fitting a small indicator lamp across the coil as a resistive suppressor ....
I'd not heard of that method before, I've always used diodes across DC coils.
My reply is slightly biased as ive just done a 1 indicator with multiple tasks i.e. solid light, slow pulse and fast pulse to notify machine stop saved loads in space and materials.Totally unsure why. I'd suggest a better practice would be for the contactor to switch a supply to an indicator to confrm the contactor has switched. I dislike using a PLC to switch an indicator lamp unless its part of a light-stack unit to inform Ops.
OK you saved on space. The space you have to worry about is the space between the operator’s ears.
I tried various multifunction flashing indicator lamps and gave it up as a bad job years ago. Given two options the average operators brain goes in to overload.
