G
Guest55
you disgust me with such cheap sullied filth :-/
Discuss NIC approved contractor assessment in the UK Electrical Forum area at ElectriciansForums.net
yes...If you dont mind me asking, what is involved in the assessment?
Any testing etc?
Thank you Paul.Well done Glenn. As if anyone would think that you would have failed?
minimum of 5 jobs for approved contractor....Firstly they check your insurance and do an office audit. They then move onto your test equipment and check calibration records. The engineer then will make sure your publications are up to current amendments. He will then ask to review your certs and eicr reports and pick out a couple of jobs to visit. Once there he will have a brief look and ask you to perform certain tests on your install and then compare readings to what you have recorded on your cert. That is about it. Most area engineers don't go to mad they just want a straightforward in and out and move onto the next contractor. It only becomes an issue if you dont keep your stuff in order and basically offer up a dogs dinner of a job or something that ultimately is not safe. But surely you wouldn't even offer up a cert if you thought what you had done was questionable!!
5...how many slaps did it take ?
i reckon 3 lol.
5...
one for each assessment site
demonstrating the spectrum of all work carried out
Contgrats My friend, it only seems easy because your a proper spark, I can assure you more than half the sparks here would fail an approved contractor assessment, your business should sky rocket now if you push it, Congrats again Glenn.Just had assessment:
passed.
Yes we know that, the 5 jobs are for initial membership. once your in it is a matter of continuing to comply.The 5 jobs is for initial registration. Annual assessment usually is 2. I've had a yearly assessment under the approved scope and never been asked for more than 2 jobs on any one visit and that was on a half day inspection.
Reply to NIC approved contractor assessment in the UK Electrical Forum area at ElectriciansForums.net
