Who cares - the time you've spent doing this could be better spent out working! Unless you are going to buy thousands you need go consider the delivery charges and/or your time/fuel costs!
Always try to avoid joints unless you really have to create one, I buy mine from Wago direct, they deliver to your door.
Agree with Murdoch they aint that expensive, by the time you've farted about trying different places to buy them you may as well just buy them from the first place you tried.
What I would add is that its probably worth buying the installers kit to begin with so you have some of all types to hand then buy the ones you use a lot of!
You are best to work out what you need then order it, as if you are going to install say 30 down lighters, you will probably go through 100 connectors.
I normally keep around 100 of each in my van, i use them quite frequently. They are really good.
My Wife never avoids creating joints, unfortunately the supplier doesn't deliver.
Installer kit £55 pound of leebay i wana go for it but lot money for me maybe a few more tinnies might persuade me . I'm currently using those lever types .. Me likey!
Cheapest place to buy Wago connectors?
Electrical Tools and Products
Lazlo,
Amp David,
