oye Nick..
stop attention seeking with sillyness like this....just shift the chuffing thing to where you want it.....
its not an addition or new install is it for christs sake...use your initiative lad...
if you feel they may be using it for outdoor equipment then replace the front with an RCD outlet.....
bloody nora...
How is it attention seeking? It's a question which was asked in a fair way and has already had different answers given by members on here. Daz
As Tel has already said, change the existing point for an RCD FCU, then come off the load side. Happy days...
So easiest way would be use an RCD socket. But think about it like this. They now have 15/20 sockets with no rcd protection and one with! Haha you should tell them to plug anything in THAT socket if they plan on getting a belt at any time in the future. I'm with D skelton. Common sense/type of punter.
No sorry I don't agree with that at all
read post 13, By adding a RCD socket you are still not protecting the cable you install, doing it the way Tel mentioned you protect the cable and new socket, the best suggestion in this thread by far and the right one IMHO.
I did a similar job a while back. Customer 90 year old, old dear, wanted another twin socket next to the existing twin socket behind the telly so she didn't have to use adaptors. Wylex rewireable board, did the essential tests, and duly fitted her a new twin socket. I ask myself this, is it safer now without RCD's or was it safer before using adaptors and extension leads?
I sleep well, knowing that i did a safe non compliant job, and if i hadn't have done it, then someone else in the pub would. You are competent enough to risk assess it, and get the job done. No one will ever get prosecuted for doing the right thing for the right reason.
Remember the regs are guidance only, and must be complied with as far as is Reasonably Practical, and not regardless of cost and inconvenience.
Cheers.............Howard
PS I await the regs brigade onslaught!
No onslaught by me Howard, I fully understand your point and Damiens and never said there was a problem. I still think though Tels suggestion was the right way and I would do the job the way he suggested myself, It would still be a fairly cheap quick job and it would be a good job.
I am all for the common sense approach, but in the world we live of litigation, I would not install sockets without rcd protection, it's all about covering one's ---!!. On that note I am sooo glad am away from domestic and contracting full stop.!!!
This afternoon I looked a job to move a 13A DSSO socket only 120mm (out from a brick wall onto a new stud wall just in front of it). Cable extensions probably required. No RCDs on any final circuits.
I'd thought that, but the original socket position is going to get blocked by a radiator, which is the reason for the socket move.
