H
Hawkmoon
I've got flu at moment so if this is a stupid/Electrical Trainee/diy type question then illness will be my excuse :)....
How do voltsticks sense live cables but not neutral cables?
They use a u shape receiver antenna in their tip which is tuned to pick up very low frequencies ...specifically in the region of 50hz and the control circuit filters out many false sources like static etc .. they tune into the voltage itself and ref' it to you by capcitive coupling usually but other methods exists. typically looking for >90v this then means N isn't picked up as its potential in reference is 0v
Thats an interesting question/observation! Dont think it will work on the magnetic field from current flow as both L & N will emit fields. I'm gonna go with something along the lines of Darkwoods answer in that somehow the voltstick senses the voltage then references it against you holding the stick as a nominal zero (or the battery -Ve). So "Live" shows 230V and it lights, "Neutral" shows 0V and it don't light.
Must get one and have a play ......
It 'references' pd to you even though it's insulated? The negative of the battery is electrically separate though?
As the neutral is emitting same em and frequency never really understood how it made the distinction
Isn't there a special part of the voltstick that you touch/hold? I assume will allow the reference to be made?
I edited it to delete confusion ... they can work in various ways but they look at the voltage waveform hence the live wire, the N is the line at 0v on the waveform chart so doesn't register as its a straight line as it uses you as a reference and you are in contact with mass earth - its capacitive coupling so its regardless that you are holding a plastic object.
Brain can't comprehend the physics of it at the moment, seemed such a damn simple thing when I first thought about it! So it even works without you touching it? Must be a bright bofffin out there somewhere who has the definitive answer .....
You don't need to touch them.
And what a weird coincidence, was only playing with my avatar this morning and added a voltstick for impact .... fate!
Look up capacitive coupling and how it works and you will understand how some volts sticks dont need to be held to light up as they ref' the AC waveform to that of the DC battery circuit to establish if something is live.
The waveform abobe shows the voltage rise and fall this is what the pens are looking at - the traight line in the middle is 0v and a reflection of the N wire... don't confuse this with current which is reflected the same in L and N
Did you touch it first to get the light then leave it --- somehow the signal is locked in from you?
Does it do the same if you leave it on the cable with it unpluged (no power) then plug in so you have power and you havent touched it?
