Only for post-FCU use where not "fixed wiring"1.25 is a fairly non standard size imo which is usually found on extension leads and 4 way plug adaptors etc
Agreed!1.5 should be used for fixed hook ups like immersions and storage heaters imo
Cheers Brian I thought overload protection wasn’t required. Looks like these were initially installed like this.If it's on a 16A circuit, then the fuse in the FCU is not required, so the FCU should be replaced by a 20A DP switch. A 13A fuse will run hot feeding a 3kW immersion heater, and the plastic of the FCU will be damaged over time.
You were at 25 characters at the “e” of “regulation”So is this an occasion where regulation 433.3.1 comes into play? I will make this 25 characters long to comply with these rules. Just about 25![]()
