B
Buners
Upstairs & downstairs on the same breaker, RCD protected board.
Views on this?
Views on this?
As bill01803 says depends on the total floor area and also what the requirements are, i.e kitchen areas (as Pat H mentioned) ideally need their own RFC as these days they tend to require many more sockets with potentially high wattage appliances.Upstairs & downstairs on the same breaker, RCD protected board.
Views on this?
Mine is 1970s one ring final in a three bed house. R2 continuity is sky high because of 1.0 cpcs.
25 years old I would guess, went around and had a look the other day as customer wanted a rewire quote, just thought it was a bit strange.
How is normal 2 bed but has had the garage converted into a dining room (extended ring to suite I think) also had a loft conversion too but without further investigation I would only be guessing.
Westie, reading your status (a bit cheeky I reckon) I'm tempted to say - I could recommend an Electrician to come over and fix your ring - Only tempted, mindMine is 1970s one ring final in a three bed house. R2 continuity is sky high because of 1.0 cpcs.
.Mine is a ring final apart from a spurred multiple outlet in the kitchen which I will sort when the kitchen is changed, mind you be saying this for the last 12 years. I have added to it and my R2 measures 2.20 ohms.My brother's old place was awful. Good size 3 bed semi, one ring for all sockets, upstairs sockets on the ring, every downstairs socket was a spur dropped from a JB above.
