Discuss 100amp Isolator switch required in the UK Electrical Forum area at ElectriciansForums.net
wylex or click do a KMF but only to 80A.
Or even 5 poles dancing
swd in the middle.LOL.
Thanks for all the replies. I have relocated my CU. It was originally next to the mains meter and is now much further. I believe I will need the isolator switch next to the meter now. I didn't realise I would need this as the whole point of moving it was so that it was less noticeable. But now I've been told I will need the switch next to the meter so I'm trying to get it as small as possible. Thanks
Assuming you are using swa you won't get much smaller than this. Lewden is generally a poor quality option but it is what it is.
Lewden 100AMP SP&N SINGLE POLE AND NEUTRAL FUSED ISOLATOR SWITCH - https://www.superlecdirect.com/p-fs6380100-lewden-100amp-spandn-single-pole-and-neutral-fused-isolator-switch?gclid=CjwKCAjwtYXmBRAOEiwAYsyl3PyBWmBRg3gV7K5M4dUBPWPgWVF1weX3cCHt2BslHNr4M8uADjQCbBoCFAMQAvD_BwE
How on earth did you carry out the cable calculations for the submain without an OCPD rating for the circuit?
Thanks for replying. I am not an electrician. I am acting on advice given to me by a friend (who is a sparky) and the electric wholesaler I have been purchasing materials from. So sorry but I have no idea about your question davesparks.
Reply to 100amp Isolator switch required in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi I have a customer who has a kiosk with 100 amp cut out fuse supplied from UK power, he needs to bring the power 178 meters to his house, He...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
