Discuss 100mA RCD on PME system in the UK Electrical Forum area at ElectriciansForums.net
kingeri
I am going to a job this afternoon, new shower circuit. I noticed yesterday that the Wylex CU has a 100mA S-type RCD as the main switch and all the circuits are on 30mA RCBOs. PME system as far as I could tell (certainly not TT). Didn't give it much thought then, but was thinking about it last night in bed (sad, I know). Initially I thought there is no problem with this arrangement, a bit unnecessary perhaps. But I was thinking, as the RCBOs are single pole, a sustained N-E fault on any of the circuits would trip the upfront RCD and take out the whole installation. Other than that, I can't see an issue with it, unless I'm missing something. Do you folks think this in itself is reason enough to recommend replacing it with a vanilla main switch, or would you just leave it in situ? And have I missed anything?
Anyone? I was hoping for something before I set off!
I obviously haven't done a Ze yet, which may explain the presence of the 100mA RCD I suppose (if it's very high).
I'ts a balance between safety and convenience. The 100mA type S is acting as a backup to the RCBOS. I'd be inclined to leave it in. Would be worth asking the householder whether it's ever tripped.
Cheers guys. I can't see it as having been TT in the past, but I suppose you never know!
I will leave it in, it is providing dual redundancy in a way!
Reply to 100mA RCD on PME system in the UK Electrical Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
