Discuss 16A 4 pin wall socket in the Electricians' Talk | All Countries area at ElectriciansForums.net
B
bikeman
This is my first post so Hi to all
I have to wire in a couple of 16 amp 3 phase wall sockets in a work shop.
The ones I have been given are 4 pin.
If I run Line 1, Line 2, and Line 3 standard brown Black Grey I am guessing the 4th pin is for earth and power is between each phase?
Just checking as I have this naggin doubt that the 4th pin would be for neutral.
I have to install 2 in the work shop and there is a spare 20A 3Phase CB on the board I am guessing I can ring each line back to the board?
Thanks for any responce
Sounds like a 3 phase supply for a motor no neutral needed. So yes L1 L2 L3 & cpc.
I personally would not wire these on a ring. I would run in a seperate radial for each 4 pin back to seperate MCB's.
as above and you also need to think of motor protection methods, you dont want somebody to test a 1kw motor using a socket on a 20amp beaker
Reply to 16A 4 pin wall socket in the Electricians' Talk | All Countries area at ElectriciansForums.net
I know the effect of a lost neutral (floating neutral) on a 3 phase system, and the theory of why the line voltages can vary. However, I have...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3...
