I always fit an isolator switch for any appliance in kitchens...mentioning things going faulty and catching fire tends to sway most of them to my way of thinking...
Though lost one job as the clients wife was doing the interior design on a rented property and "didn't want those ugly switches on show" and they "all have to be in the back of the cabinets hidden out of sight"...no chance...he saw the point, i think she threw a fit as I've heard nowt since sticking the quote in weeks ago....
Got a job on tomorrow...re-lay a cooker supply....as previous owners rejigged the kitchen, put in a gas cooker and their spark just extended the ring for the cooker igniter and turned the old cooker/oven supply into a socket with random spur....not what I was hoping to find...was hoping it was just the usual cooker outlet plate previously swapped for a single socket...
I really hate crawling under newish build house floors (no room to move as the builders backfill them with crap and ends up like being on an assault course)...and I have to lift laminate in a cupboard to cut a hatch (Though owner is ok with it getting wrecked if thats what it takes to get access to the floor below..says he'll get a carpet if needs be for the cupboard so one saving grace)...'kin hell....this is going to be a LONG day tomorrow....still work is work...
The switch is not required for isolation.
It depends whether you think emergency switching is required for an oven.
OK for TN, then. MCB, that is. Section 537 & Table 53.4.
Sorry, just checked my definitions. I thought of 'live' conductors as including neutral, but realise 'line' does not include neutral!
Yep.
Why do people keep quoting the OSG instead of the actual regulations?
I guess its because BS7671 is pretty scary and reads like a law book! I should have said 537.2.1.1, but seeing as though that says it doesn't need to be DP, we'll just say 'It's good practice so just do it' :D
Commonsense would tell any competent electrician to provide a means of local isolation to fixed equipment. It certainly wouldn't tell him to remove any perfectly sound existing means of isolation....
Regs are what we must follow,
good practice is what people think should be done, right or wrong
common sense is almost non-existent.
And not forgetting the fourth option ....... forum guidance which can be a mixture of all of the above!
If you're not competent to do otherwise, you'd be a fool not to follow BS7671. What i mean by ''Competent'', is being able to stand up in a court of law and successfully argue your departures are technically sound and safety has not been compromised etc...!!
Well yes obviously you would be a fool not to follow the regs and like you say if you get dragged into court your goosed. And yes it wasn't really the most helpful of things, but it is a fact.
well, if following regs. meanss drilling into a RFC in the wall, i'd be wary. LOL. :furious3:
