Discuss 2 way switch induced voltage? in the UK Electrical Forum area at ElectriciansForums.net
Hellmooth
Got a 2 way switch that gives 43 volts down one strapper when off, could this be an induced voltage, and if so why isn't it on the other strapper when it is off?
Also voltage at light switch is 250-252v, the light switch was faulty under load so couldn't be switched, when powered down it switches fine, it is rated to 250v, could this cause an issue?
Hi
Yes sounds likely, probably not on other cable due to seperation distance.
Dont see an issue with voltage.
Cheers
Yeah did think it would be.
I wouldn't think it would be an issue, any ideas why it wouldn't work under load but ok when switched off?
When you say OK when switched off, you mean has continuity?
If so the contacts are so badly burnt they'll allow continuity with the very low current from a meter but break down under any load.
When you say it shouldn't be a problem it still should be sorted out your aware of it so rectify it. It will be come a problem for someone the next time it's tested cos your meter won't allow you to do dead testing as it will detect a voltage, I've had this once before when trying to do an insulation resistance test my meter wouldn't give me a reading a warning light comes until you detect the induced voltage.
I didn't check for continuity, I mean the switch wouldn't move ie was stuck solid with a load on it, when switched off it worked fine.
And Farm I didn't say the induced voltage wasn't a problem, I was replying to Geoff when he said the voltage of 250v wasn't a problem............
Yes an mft won't allow dead test when it detects any voltage.
Reply to 2 way switch induced voltage? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
