- Reaction score
- 609
Got a 2 way switch that gives 43 volts down one strapper when off, could this be an induced voltage, and if so why isn't it on the other strapper when it is off?
Also voltage at light switch is 250-252v, the light switch was faulty under load so couldn't be switched, when powered down it switches fine, it is rated to 250v, could this cause an issue?
